Everything posted by wldbil95
rear LEDs
Ya I suppose I should've been more specific, usually helps. I have 4 run, turn, brake oval shape (2"x 6") LEDs in back. the very top and very bottom light up bright, but the one's in the center or middle are only lite up real faint. my welding rig is DOT'd so that has me a little nervous since I have to leave with it today. As always, Thank you.
rear LEDs
hello everyone, got a question. what would cause only two or three of 10 bulbs to light up on rear (run, turn, brake.) tail lamps?
abynormal hi idle
hello again, I noticed something funny tonight when I pulled in the driveway. after turning stereo down, I went to turn truck off, turned key backwards and pulled key out but truck stayed running then I looked over at the tach and truck was idling at 1200 for no apparent reason. much higher than usual. while it was still running I check the juice module to see if the turbo cool down was on. but it wasn't. at the time it made sense because I had just driven 13hrs. Any thoughts? thnx in advance, Bill
2001 6 speed manual
hey , that one is a 2012 pipepro 350 cat turbo. I also have have a 06 big 40 cc/cv been trying to sell it.
2001 6 speed manual
as it turns out, the #2 fuel line was loose after the head gasket job i had done back on thnx giving week. every time i have work done to my rig something goes wrong. had tires rotated the other day at discount tire and they scratched the hell out of the new ultra 024 front rims. god damb kid didnt even say anying noticed it when i got home. damb kids. thnx for all your input. your the best.
2001 6 speed manual
the guys at the shop are convinced its diesel fuel dripping down. but no visible leaks. hade a head gasket replaced bout thnxgiving time. one guy says could be o rings on injectors.
2001 6 speed manual
thnx for the info. im wondering about the slave hydrasulic clutch assembly because the fluid is mostly clear.
2001 6 speed manual
hello everyone, I've just pulled my pipeline rig out of storage. ( 01 3500 dually with 6 speed manual ) and noticed good sized puddle of gear lube under flywheel while it was running parked out side of discount tire. Do these things seal them self's back up after running for a while ? or should I start looking for a shop ? Thnx Bill
VP or something else??
I have the same starting issues. Seems to happen when truck sits for a day or two. Like it,s bleed off line pressure. someone was talking about a return line check valve ?
01 head gasket recall ?
well i just got the truck out of the shop. i noticed a funny smell so i opened the hood. everything looks ok, but i noticed that head heas some new paint on it. not spray paint either. looks like a thick shiny industrial paint that is burning off. they said the head was worped and has to be machined. ok do it. on the way home i thought to my self, where is all the power ? then i thought no worries your just being noid and take it easy on the new parts. but yet another thought crossed my mind. how can i know for sure that i got the right head back that belongs on the H.O. 5.9L TD ???
i bought the truck back in 9/09. i think that postcard sized notice came the following summer. i've torn the office apart, but no luck. thank you for taking the time to look this up for me. happy thanks giving and merry christmas to all.
hello every one. i seem to remember getting notified by mail about a recall for head gaskets for my 01 5.9. Does any else remember or know of a recall simular to that ?
Extreme cold!!!
max dahl's canvas craft. 218.897.5000 bemidji,mn. area. it comes with a summer mesh to 65-75 $ he's got all the patterns.
Minnesota big cat
2001 SLT LARAMIE 5.9 24v H.O. 6 spd manual, fass 150 lift pump, banks ram air cold air box and intake, juice w/ attitude , 4" cat back dual out, 3.55 gears, horn blaster air barge horns, warn 12k winch, 28 gal aux fuel cell, firestone riderite air system, alpine, kicker amp/subs, jotto desk, Wilson booster, 2012 miller pipe pro 350 CAT TURBO.
squwishy clutch pedal
thanks a bunch for taking some time to help me . Once these things start to go, how long till there gone completely ?
hello everone, I have an 01 5.9 HO TD with 6 speed manual. today me and the kid were out picking up a welding machine on a small trailer and coming up to a stop sign, go to push in clutch and felt it go limp right to the board. what now ? I'm think,n. sitt,n there i started pumping and after a couple it came back to normal. had about 20 miles left to go. it did it again intermittently a few times but not consistantly. I would greatly appreiciate any and all feed back. THX
Mopar1973Man's Crankcase Vent Modification
hello every one. glad to find this forum. i too am having crank case breather issues and i like mopar mans simple fix. however i cant help but wonder what kind of a mess is that leaving under the truck ? if any ? thx
