guesswho512
  1. guesswho512 posted an Cummins article in Electrical
    Starter Contacts Disconnect and isolate negative cables of both batteries. Raise and support vehicle. Pull back protective rubber boot from solenoid battery terminal far enough to access and remove nut securing battery positive cable wire harness connector eyelet to solenoid battery terminal stud (Fig. 10). Remove nut securing battery positive cable wire harness solenoid connector eyelet to solenoid terminal stud.(17mm) Remove battery positive cable wire harness connector eyelets from solenoid terminal studs. While supporting starter motor, remove three bolts securing starter motor to flywheel housing(8 or 10mm 12 point bolts, use box wrench or suitable socket) Remove starter motor from engine (certain diesel engines have an aluminum spacer mounted between the starter and the starter mounting flange. Note position and orientation of spacer before removal). Now some of the basic tools you'll need. Now you can take the nut on the other side off(15mm). then a phillips screwdriver removes the 3 cap screws. When the cap comes off the plunger springs out. there is a little ball behind the spring(mine didn't come out, but remember it is there, don't lose it). With the plunger out of the way, you can take the out side nuts off the studs. because of the plastic guards, i could not get a good enough bite with a wrench and with a impact gun made short work. With the nuts off, you can remove the studs the contacts are press on the studs. Swap the old contacts for the new ones. Try to keep the contact touching the back plate while tightening the nut (they try to twist when you tighten). Take the spring off the old plunger and place on new one put the ball in if it came out. Insert new plunger and replace cap. Connect the wire to the stud and install starter on truck! Article Wrote By: GuessWho512 http://forum.mopar1973man.c
  2. Starter Contacts Disconnect and isolate negative cables of both batteries. Raise and support vehicle. Pull back protective rubber boot from solenoid battery terminal far enough to access and remove nut securing battery positive cable wire harness connector eyelet to solenoid battery terminal stud (Fig. 10). Remove nut securing battery positive cable wire harness solenoid connector eyelet to solenoid terminal stud.(17mm) Remove battery positive cable wire harness connector eyelets from solenoid terminal studs. While supporting starter motor, remove three bolts securing starter motor to flywheel housing(8 or 10mm 12 point bolts, use box wrench or suitable socket) Remove starter motor from engine (certain diesel engines have an aluminum spacer mounted between the starter and the starter mounting flange. Note position and orientation of spacer before removal). Now some of the basic tools you'll need. Now you can take the nut on the other side off(15mm). then a phillips screwdriver removes the 3 cap screws. When the cap comes off the plunger springs out. there is a little ball behind the spring(mine didn't come out, but remember it is there, don't lose it). With the plunger out of the way, you can take the out side nuts off the studs. because of the plastic guards, i could not get a good enough bite with a wrench and with a impact gun made short work. With the nuts off, you can remove the studs the contacts are press on the studs. Swap the old contacts for the new ones. Try to keep the contact touching the back plate while tightening the nut (they try to twist when you tighten). Take the spring off the old plunger and place on new one put the ball in if it came out. Insert new plunger and replace cap. Connect the wire to the stud and install starter on truck! Article Wrote By: GuessWho512 http://forum.mopar1973man.c View full Cummins article
  3. i don't know if i missed it, but jasper has a pic of the "diaphragm" here: http://www3.jasperengines.com/blog/2011/12/02/jasper-remanufactures-vp44-diesel-injection-pumps/ so i think it's safe to say that yes, there is a diaphragm and yes, it can be worn out or damaged. just my
  4. when you installed the FASS system, did you use a diesel compatible thread locker? i found one at a local part store that was marketed for marine applications. i used it on all the threaded ports when i installed my airdog 150 and i personally believe that is why my truck holds a prime for over a day. if you suck air in, then you will have trouble similar to what you describe. i'm not a mechanic, i just play one on TV....and i stay in a holiday express last night. https://www.youtube.com/watch?v=7jo_x7ecIFg just in case you missed the joke
  5. i was under the impression that dana 80's went on the diesels and the dana 70's went on the gassers for the years of 98-02. please correct me if i am wrong. also having a 2wheel drive truck, i love having the limited slip in my dana 80...but i do wear the tires out faster on the rear. i think if you change from factory drums to discs, then you have to change the master cylinder. if memory serves, drums work on pressure, and discs work on volume of flow. so you would need a cylinder matched to you application.
  6. for the starter contacts, read this write up: http://forum.mopar1973man.com/index.php?/topic/1364-starter-contact-write-up/ also...if the truck is not starting right now, the contacts are the problem(which they are 90% of the time with this problem), and you need to use the truck before the replacements come in, then you can follow the steps of the write up, but only remove the 1 contact that is thin and make the hole longer, allowing you to get the contact closer to the plunger. i did that with my truck and it allowed me 2 months(possibly longer, but i finally broke down and ordered the replacements) before i change them with the new ones for troubleshooting the airdog, if the fuse is good: take the airdog relay out in make a jumper wire. with the key to "on", but not cracking the starter, place the jumper wire in the relay socket were it jumps the yellow and red wires. the airdog should run constantly. if it does, then you can confirm it is the relay by taking one of the big 5 blade relays out of the PDC and placing it in the airdog's relay socket. then when you crank the truck, the airdog should come on.
  7. i respect your thoughts, but a little food for thought....the VP44 don't work without electricity! furthermore, you get air and water separation from an airdog. as well as a lifetime warranty. i've had mine for over 5 yrs now with nearly no problems (leaks, electrical, etc) until what i mentioned in this post: http://forum.mopar1973man.com/index.php?/topic/7966-need-help-asap-with-airdog/ i am not a spokesman or get paid by airdog. i'm merely a member of this forum trying to give other members insight based upon my experiences.
  8. i would like to clarify....pureflow guys in jefferson city, mo were very kind and friendly(the one's up north, Illinois i think, not so much). the guy i dealt with from MO was named Jeremy. he seemed knowledgeable and seemed like he wanted to get my truck back on the road asap. i did have a lifetime warranty, so all i paid for was shipping both ways...$17 to go from okc to jefferson city and $13 for the return trip. the airdog 150 is still going strong after they repaired it. they claimed to have flow tested it before sending it back to ensure it meets all their specs. i would recommend this product to anyone i with a diesel truck. i have been running fleetguard stratopore FF5613 filters and a baldwin BF1275 water seperator after the airdog originals needed replacing. mine is one of the 1st installation kits that required drilling the tank for the original designed draw straw. i have had my airdog for 5yrs or longer before this problem sprouted up. on a slightly different note...my truck rolled 215,000 miles yesterday. if memory serves, i purchased this truck from the original owner with 87,000 on it. oils for the motor, trans, diff, filters, and the 1 bent push rod....thats pretty much the only "work" that has been done to this truck while i've owned it. the farmer that i purchased from stated that he had to have the dana 80 worked on due to the pinion bearing dieing. so what a great truck!
  9. lol, hope you don't think i was upset....i know u work hard to keep this community going. looks like i'm "a OK".....get it, i'm in oklahoma AND my account isn't in lost family member...
  10. got the pump back from pureflow and it works like a champ. it appears their assessment, that the motor was going south, was correct. thanks to everyone for help/advice. pump has been on the truck for over a week and no problems.
  11. after taking it to a buddy's house, the fuse blew in about 60 seconds with the relay removed and a jumper wire in the relay socket. it was the first time that test failed. i think that pureflow's assessment was correct. i have decided that im well under 500hp so dont need more flow, and the sound of the airdog is what alerted me to the problem. therefore, i shipped my 150 to jefferson city, mo.... thanks to everyone for your thoughts on this problem...i had me tricked. i will update u guys when the pump is on the truck again.
  12. i'm sure this is the upgrade; http://www.pureflowtechnologiesairdog.com/airdog-model-engine-info/commercial-transportation/universal-airdog-fpii-150-200/
  13. one of pureflows test were to use a different relay(a 5 blade from the factory PDC box under the hood) in place of airdogs relay. when i did that, the fuse lasted 45-60seconds (of the 9 fuses blown so far, was the longest lived thus far)
  14. me too....im pretty good with troubleshooting, but im stumped. correct,but the truck is not running(ie started), as pureflow's instructions said do not start the truck.....that is why im stumped. i think u are confused. OHMs is resistance, and u should not check for resistance on a energized circuit. all the places to check voltage read ~12.6volts(pump connection, relay socket,and inline fuse). all the tests for continuity came back 0.00 or 0.01....open is 1.0. i just got in touch with pureflow, and they seem to think the motor needs to be replaced. i do have a lifetime warranty so they gave me 3 options. 1.send them the pump, they fix it and test, then i pay return shipping 2.they send me a motor after i pay a $150 core charge and pay for shipping 3.i can upgrade to a newer 4G pump that they claim is quieter and has more bells and whistles, for $299 i have a problem thinking its a bad motor cause it does blow the fuse with a jumper wire...anyone with ideas???
  15. perhaps, i do have a multi-meter(hence how i did the troubleshooting steps from link in a previous post i switched it out with a 5 blade from under the hood in the PDC, it blew the fuse in less than 60secs after the truck started. u are thinking the same way as me.your 1st two sentences are spot on. to the last question, yes. one off the steps on pureflow/airdog's troubleshooting webpage ( http://www.pureflowairdog.com/troubleshooting.php#pump-quit ) said to remove the airdog's relay and use a jumper wire to connect the yellow wire and red wire at the base. it is like the top. it does NOT have a fuse between the trigger wire. the fuse is in-line between the positive from the battery & the relay on the tests that i check for voltages all are normal. all continuity test came back good.
