All of a sudden the truck started acting like it had a miss
So while out running some errands today all of a sudden my truck started acting like it had a miss. I limped it home and pulled the codes to find a P0602 - ECM fueling calibration error. I cleared the code reset the ecm to stock settings and started the truck up and it's still there. I reprogrammed the truck to lvl 6 started it back up and still no change. Is there a way to check if its VP or the ECM? Thanks in advance to the help everyone.
Battery disconnect does nothing. All you need to do is turn your key OFF to reset the computers. Even time you turn the key ON the computers do a fresh reboot. This tells me the ECM does indeed have internal issues and should consider re-flashing the ECM with true stock software and seeing if that fixes it. If not the on-board flash PROM is damaged and not holding data properly.
