I looked it it closely once. And thought it can be done but carefully. The float arm and potentiometer come as one part. I only know that. When mine goes bad I'm going to try and use one from West Marine, for a boat tank, cause I don't like the looks of the Dodge one. Boat stuff is made to be changed out a little bit easier and is a bit better quality.
I got the sender float arm off. Also the small bracket that held arm and circuit on.Also unplugged wire harness . But dont know how to unplug the two wires from the plug itself
