03/05 injector spray angle
- Replies 15
- Views 17k
AH64ID 6 posts
DESERTTOYHAULER 4 posts
organicfarmer 3 posts
Wild and Free 2 posts
The spray angle is matched to the piston bowl shape. The 03-04 spray angle can be used in the 04.5-07 bowl and it seems the results are good. The 04.5-07 nozzle cannot be used in the 03-04 piston thou
That would be why it smokes! Thou it shouldn't be spraying outside the bowl, the 04.5-07 injector nozzle is a narrower spray pattern and sprays deeper into the piston. The diagram above sh
G-DAY TO ALL! i have the 04.5 Cummins and would like to uncover more facts/understanding about inj. nozzle spray angles.
my inj. seem fine, but i [& perhaps you] want to sort out some questions on inj. options BEFORE i'm needing to replace.
A rather expensive replacement part!! Lets do it right!
as the title says, some use 03 inj. on 04.5+ eng. i'm thinking of a moderately mod.ed eng. [not 500++ hp]
would i lose hp [305 vs 325 hp]?
at what hp level dos the spray angle become a danger? [assuming it does]
