hydroboost/master cylinder issues
I've had a leak in this area for awhile now, and today I broke down to rebuild the booster. In the process of removal of things, I found my leak is only between the master and the booster. Now for the crap part, I can not find the oring, rubber seal or whatever it maybe anywhere. Local, auto zone doesn't have oring this big. Anyone have a part number or a knowing of where I can get the ring?
On the subject of the hydroboost. I recently did the re seal thatso on the forum. Well the PS pump seemed to be lagging so I went ahead and replaced it. Well I filled the pump and started the truck it felt fine for a second then I started getting a moaning noise the wheel shutters and the brake petal shutters when depressed. Didn't want to start a new thread for this since its related to the hydroboost
It started right after I installed the new pump.I've lifted the front tires and turn the wheels lock to lock numerous times. I thought I solved it but 5 minutes down the road and the brake pedal was pulsating again and the moaning noise was back. But I have noticed that if the engine is over 1100 rpms all the symptoms stop. All the noise is coming from the hydroboost and it visibly moves when it's pulsing.
