wait to start light stays on (no codes)
If you want to verify the IAT use a live data tool and see the actual IAT temp and see if it showing a normal number.
Note: Even with a IAT sensor missing it the wait to start light should cycle normal and go off.
So this points to a internal ECM problem which could be caused by a bad alternator with high AC noise issues.
Could be the ECM. Previous owner installed an on/off switch to control the alternator because the PCM was over charging it. Who knows how much damage was done before I got the truck. The light was missing and I replaced it and functioned normally for awhile. Installed an internally regulated alternator and charges fine now. AC measures. 07 volts at the alternator with all accessories on.
