Fuel sending unit lines
My fuel sending unit lines are rusting and starting to leak.  Does anyone know a fix for this?  I found a company, Tri-Starr, that makes just the steel replacement lines for $159.  Looks to be good quality.  Should I replace the whole unit or just the lines?
http://tristarrradiator.com/dodge%20ram%20diesel%20page/dodge%20ram%20diesel%20page.html
It seems expensive for the part, but not sure what else, other than the fuel level sender, can go bad. Vulcan performance has the entire basket plus the sender in one package. It appears it can be set up to better use your AD with also.It of course it costs more money but looks like a better bang for your buck. http://www.vulcanperformance.com/category-s/81.htm?searching=Y&sort=13&cat=81&show=50&page=2
Scroll to the bottom of the page and you can see the choices  they have. If you have any questions they are more than happy to help you.
Edited by dripley
