hey Mike, I remember you once showing me a module that plugged into the OBDII port that showed all sorts of engine info, any chance you could send a link to me? I'd like to get one for me and one for the ol lady for christmas I think.
  • Replies 10
  • Views 3.1k
Really simple... It's listed in my BOMB pages.. http://mopar.mopar1973man.com/2002%20Do ... gauge2.htm Your looking for a ScanGauge II It even got a few new thing added to it now... Like how about your very own private Dyno... http://www.scangauge.com/support/horsepower.shtml <- Display instant HorsePower! And updated commands! http://www.scangauge.com/support/pdfs/XGAUGE.pdf
It will work even on your 04... :thumbsup
My current truck is an 04.5!! Will it still work??
from what I understand it will work with anything that has an OBDII port, which your '04.5 will have, so yes it should work.
In other words.... You better order yourself Christmas present!!!! :$: :$: :thumbsup
Link to the list... http://www.scangauge.com/support/Compat ... cles.shtml
WORKS ON ALL EXCEPT: 2004.5 through 2005 Dodge Diesel Trucks. Jeep Liberty with the diesel engine does not report fuel use or trip functions and some of the gauges. Unless the recall ECU software update has been completed.
Sorry I guess it doesn't work on your truck... :rolleyes :(
ok.... you now have the right to call me a dumba**..... but only once.... :|
No... I was posting the same way as you did and desided to go check and be sure... Would you know it I had to erase my post and start over and post the truth... So don't feel bad I was doing the same thing and figured I better not assume... ASSUME - To make a Arse of You and Me... :rolleyes
That really sucks that is doesn't work for just a half a year.... 4.5 - 5.0?? GEEZ.... `:( But what is this about UNLESS the software was updated?? Could this be a loophole that could be upgraded so it could run on Joe's truck??? :thumbsup Maiden
