thoughts on servise.
Killer223
so this weekend i'ma change the oil in the rear dif, t-case. not doing the front dif as i checked it and it's color is still nice and clean looking, i know i spins all the time but under no load maybe kept it cleaner longer.
for the rear the manual calls for a synthetic 75-90, will the normal conventional, 80-90 be ok? i have a few gallons of this on the shelf.
the t-case calls for atf+4, however my 93 toyota calls for atf as well and i use 30 weight non detergent oil in it. would that be ok in the tcase on my dodge as it is in the toyota??
You can run the regular 80-90 but if you tow heavy I would change it more often but like Mike said if its a limited slip I would definitely stick with the synthetic 75-90 as well..
As far as the t-case I would definitely stick with atf.
Edited by Wild and Free
