Hi guys, what I got is a 99 Cummins I recently blew the driver side headlight. I have a harness that goes from my passenger side headlight plug over to my driver side but doesn't plug in. I have a hid kit installed with ballasts. My problem is I don't have high beams I only have lows. So I checked the pins, fueses on and on. Then i unplugged the aftermarket harness and put in oem 9007 cheapie bulbs and what I found out is driver side works fine high and low my passenger side though only works on low. and I keep blowing the fuse 15 amp rt headlamp under the hood. I don't know if I have a short or a fuse I'm not seeing or that harness is shot and someone knows where I can get another any help is greatly appreciated. Thank you
It sounds like you have some bad wires. I'd start tracing the high beam wire(s) until you find the break / short.
That doesn't just break apart down there with a another plug
Also I'm getting on the dash panel. With the two oem lights on I get the high beam light on the dash won't go away even with I change it to dim.
4 hours ago, Me78569 said:
use a multimeter and check for shorts to ground and 12v at the plug.
The decide what to do from there.
Yeah I'll have to check the Volts only thing I did was test light. What am I looking for in the volts to ground.
