- Replies 8
- Views 2.6k
leathermaneod 4 posts
Haggar 2 posts
Royal Squire 2 posts
Popular Days
Never use acid core on anything electrical. The acid causes corrosion
Thanks for the replay @Haggar! I actually re did it last night before I got your reply. Turns out I had more cable to work with than I thought. Here are the before and after pics The old end afte
Tickled you had enough wire! That way you won't ever wonder..."did I do the right thing?...." Looks super! thanks for the info on the harbor freight crimper! Hag
Hey all,
I need to solder the end on my alternator cable to get a better connection. The one on the large cable that connects to the stud on the back of the alt. I replaced it in the past and did a really rough crimp and solder job with pliers and a torch. I've learned some things since and want to re solder it to get a better connection. I got a 150/240 watt soldering gun with a pretty hefty tip to use. My question is, should I use rosin core or acid core, or does it not matter? I know you cant use acid core on electronics, but I'm not sure if it matters on something bigger like this...any suggestions? When is it ok to use acid core and when is it good to use rosin?
Thanks!
