- Replies 10
- Views 7.4k
IBMobile 4 posts
GSX455 4 posts
Mopar1973Man 1 post
Hawkez 1 post
Also there should be battery voltage at the black/light blue wire at the sender. this voltage comes from pin # 17 at the PDC. The voltage should be less on the dark blue/white wire that comes out of
I installed my sending unit and fixed the broken quick disconnects with Larry B's kit.
My fuel gauge still does not work. I did the cluster check, hold the odometer button down, and the gauge functions, etc.
The resistance when the tank is empty was about 210-215 ohms; 20 ohms when the level is moved to full.
I get these readings at the connector on top of the tank. Is there anything else, besides the harness being bad, that would make the fuel gauge not read?
Thanks for any suggestions, the truck has 350k miles, and things are breaking down at an alarming rate.
