Strange noise under oil pan
What kind of fuel system do you have on your truck? It would be helpful If you fill out your signature as to what truck you have and any modifications you have done to it. You can do that in your profile. That way it will appear on every post you make.
 Does the pump have a problem? I am asking because the fuel line should not be vibrating as you describe. The fuel line might be transmitting the noise. Not sure just spit balling.
 If you look at the bottom of my post you will see my signature. It appears on all of my post so everyone knows what I am running. That is different from the bio. Not trying to beat you up it just helps.
