Cowl plugs
Anybody know where I can get a couple cowl plugs...
Not sure what they are called.
You have to pull them to take the push rods out.
The rubber grommet things up under the cowl.
2004 2500 4*4
  • Replies 5
  • Views 3.2k
I would give Cummins or CPP a call and check prices.
Find the Part number in the lookup tool
Under exterior panels, under plugs ~ page 888 and above
Edited by Me78569
1 hour ago, Royal Squire said:
Wouldn't this be a dodge part?
Yes.  But cpp sells a lot of engines and cummins has the parts as well.
You can try dodge as well.   I bet dodge and cummins come in the highest.  If you want cheap, you could call the local engine builders as most i know seem to have 3rd gen motors being rebuilt or junked from washed cylinders.
Edited by CSM
