99 cummins turbo drain hose
I crawled under my truck recently looked up and found under my oil filter there is a leak coming off a hose with two clamps. Traced it found out it goes to the turbo. I haven't taken it off so I don't know what size I need or what it is. If it is special hose or the length of the piece. I looked online found 3/4 7/8 silicon high temp you name it etc. can anyone help me out here thanks.
Pretty sure the drain hose size is 7/8" ID,  that little hose that hooks the block to the metal turbo drain line. I tried 3/4" heater hose and it wouldn't fit.  You could try looking up the Cummins part # and see if there's a size description. Or take it off and measure.
