ADR9802_4kV2
View File
ADR9802_4kV2
V2 tuning for the 4k Adrenaline.
V2 tuning will allow the user to customize how much fuel is being sent via the CAN bus per PSI of boost.
Adjust timing for every 500RPM starting at 1500 RPM and moving up to 4000 RPM
Adjust timing for high throttle low boost. Adjust timing for low throttle low engine load.
Lots and lots of adjustments.
  • 2 months later...
  • Replies 3
  • 7 months later...
  • Current Donation Goals
    • Raised $20
