Fuel tank straps
11 hours ago, Dieselfuture said:
You can probably pop most of that dent out by hand should be pretty easy, I'd try it if it was me. Maybe stick a 2x4 with a ball of rags on the end so you don't put small dents from 2x4 in a box and pry it out.
I went to pop it out already but the paint is cracked and wanted to flake off a big piece so I just stopped.
Finished the Rear main seal, Velair DD clutch and rebuilt trans install about 2 and a half hours ago and put almost 70 miles on it. Last Friday I got a pivot ball for another "just in case" and well..  But the new clutch is pretty and no more third gear grind which is nice. But the DD nature shifts like a tank
Edited by Cronus577
