Electrical short?
When I hit my brakes hard all my lights and radio and everything went out and came back as soon as I let off the pedal. Does this mean electriacal short?
  • Replies 21
  • Views 5.9k
  • Mopar1973Man
    Good place to start. I would monitor fuel pressure during these hard starts and see if the gauge drops out. If so that is an air bubble coming through.
Normal. The grid heaters draw 95 Amps for single element and 190 for both elements. So every time the grid heater cycle on for post heat it will pull the alternator down hard. I typically attempt to either set high idle to help keep the RPM up so the truck can warm up without straining the alternator or start and get rolling quickly because after 20 MPH the grid heater are disabled. This goes back to what kills the alternator diodes and creates the AC noise issue because the alternator isn't turning fast enough to cool the diodes so the overheat quickly and fail. Another reason some of us unhook the grid heaters in the spring of the year.
