Smoke and runs rough
I just installed a reman 5.9 in a 2007 2500 4x4 started truck and idled fine went to test drive started to accelerate could hear the turbo start to build boost and then it started knocking and smoking bad
  • Replies 4
  • Views 1.6k
Since you just installed the engine, I would check all air intake connections for the charge air circuit for boost leaks from the turbocharger outlet to the air intake plenum on the engine.
- John
No codes double checked everything
