Need help identifying a turbo
The bolt is seized on the clamp so I can't get the compressor cover off. I don't want to snap the bolt unless I plan on using the turbo. There is no play in the shaft but the compressor wheel has some chips on some of the blades. So I would rebuild it anyway.
I measured the compressor wheel opening, just over 66mm, and the exhaust opening is just over 78mm.
