1998 dodge power mirror problem
I ordered towing mirrors off amazon last year. Got them in and installed them, I hook them up and tested both sides before putting everything back together. Both worked, Installed them, Passenger side still worked, but driver side didn't. Emailed company they sent out another set, error happened and I got 1 correct and 1 for a 2010+ sized mirror. Emailed them they sent out another set and they were correct. months go by and I didn't have the need to change the mirrors out as i already had them adjusted to where i needed them(folded down) I did some trading with a friend and traded him the mirrors that were messed up for a leveling kit and some cash. We took old ones off and up new ones on my truck. Tested before installing them everything worked great. Start the truck and turn it around in the driveway. My driver side works fine now but my passenger side on goes left and up folded in or flopped out. Im not a wiring guy and I need help figuring out why it has done this.
  • Replies 4
  • Views 1.7k
I have a friend bringing an extra door panel with power switch to rule that out
I would say you are welcome but it seems you have solved the problem yourself. Good to hear all is well.
18 hours ago, Waydin_Stewart said:
It was a pinched wire. Thank you!
I just went this as well. Very careful routing of the wires when installing makes for happy mirrors.  Took me a while to figure out as well. Glad you did too
L8tr
D
