3 hours ago, mountaindan said:
Will a ECM from a same year truck automatic work in my truck to test it , mine is a manual, or will it Vin lock?
I just spent good 30 or so minutes on the phone with https://autocomputerspecialist.com
And from what I understand for testing purposes you could put a different ECM in but it has to be pretty close four years and options, they did not recommend driving it that way. I do not believe they Vin lock themselves, that's a smarty thing.
Well I got my truck back today.  The problem was a injector, I had put a bad one in don't know why they didn't catch it when they installed the tips. It now has a set of RV 275s in it.  While it was in for repair I had the clutch replaced, leaking wheel seals replaced, valve's adjusted and transmission output seal.  Getting ready to tow the RV next week to check it out. Ran great on the way home, finally no miss.  The mechanic treated me good on the price.  Anyone have trouble near Waynesboro PA message me and I will recommend a great desel mechanic.
Thanks to Moparman1973 for taking the time and give me recommendations they were a great help.
Thanks to all members for their comments they were all taken seriously
Guest 04Mach1
Awesome... Enjoy the great running engine.
Back when I first joined this forum I had an issue with my 01 running weak and too clean. I ended up putting a 6 pack of new Bosch RV275 injectors, new map sensor, and Airdog lp. A while later I came upon a great deal for a Smarty S03. I'm content with the engine performance now with the smarty set on fuel saver.
