- Replies 7
- Views 3.8k
Mopar1973Man 3 posts
Quadzilla Power 2 posts
JDHudsn 2 posts
Popular Days
There is 4 ways to kill a VP44... 1. Low fuel pressure. Typically low fuel pressure problems caused the P0216 code. 2. Poor Filtration. I've seen several trucks with the stock filter
Way better than I could have ever put it.
No. There is no electronic tuner with a P-pump. Not to mention there is no timing advancement with a p-pump. It's a static timed pump what timing you set it for is the timing across the ra
Ok guys I need some schooling. Can you run a P-Pump on your 24V and still have some V2 tuning options? Or do most of the tuning parameters lie within the VP44?
