47re built transmission NO OD
A stock valve body is a recipe for burned OD clutches no matter which converter is being used! LOL Dave's VB will give you plenty of pressure, so you shouldn't have that same problem.
I use Raybestos GPZ's in every 47RE/48RE that I build, and can't recommend them highly enough.
