Looking for Staff Members
Hi everyone ive just been doing a few small odd jobs on the truck one issue i have is the seat switches they all work apart from the toggle switch to the right of the square switch.. what does this switch do and is there any common faults with this adjustment
thanks ??
  • Replies 7
  • Views 2.7k
Lumbar adjustment. Most likely the compressor or vent valve. Up should run a small compressor pumping up the bladder in the lumbar area. Then the down should vent that back off deflating.
My lumbar works on the far right switch ? that works ok.
  On 8/7/2018 at 9:58 AM, Ronniemx3 said:
Hi everyone ive just been doing a few small odd jobs on the truck onimageproxy.php?img=&key=4d11e5b7ded08803imageproxy.php?img=&key=4d11e5b7ded08803e issue i have is the seat switches they all work apart from the toggle switch to the right of the square switch.. what does this switch do and is there any common faults with this adjustment
thanks ??imageproxy.php?img=&key=4d11e5b7ded08803imageproxy.php?img=&key=4d11e5b7ded08803
Are you asking about the switch on the left?  That raises and lowers the front of the seat.
The 3rd switch from the left isnt working the one i need to know the function of
Thanks man
  On 8/8/2018 at 12:38 PM, Mopar1973Man said:
Rear tilt. It will raise or lower the rear of the seat.
Thank you @Mopar1973Man i will have too rip it apart and try find the issue
