Was trying to find idle RPM stuff and somehow got to banks, never been there so clicked around and came across statistics. So I went to this page; http://www.bankspower.com/products/show/138/31
At the bottom of that page: Maximum speed, hill-climb, towing (measured on a 7% grade) 47 mph (2nd gear)
Test Vehicle: 1995 pickup with 5-speed manual trans
So I did some figuring and I gave them the benefit of the doubt and put on stock 4x4 tires which I think are the 265/75/16. Even then, they would be doing 5371.8 RPM at that 47mph in 2nd. Even worse, 47MPH is 2951RPM in 3rd! Redline on 12v is 3000, with most of them being lower because of hard defueling. All of this was with a load of 10,800lbs.
Which leads me to believe I can't trust any of their data at all. Funny when they mislead you on something you can calculate to be absolutely wrong
Was trying to find idle RPM stuff and somehow got to banks, never been there so clicked around and came across statistics. So I went to this page; http://www.bankspower.com/products/show/138/31 At the bottom of that page: Maximum speed, hill-climb, towing (measured on a 7% grade) 47 mph (2nd gear) Test Vehicle: 1995 pickup with 5-speed manual trans So I did some figuring and I gave them the benefit of the doubt and put on stock 4x4 tires which I think are the 265/75/16. Even then, they would be doing 5371.8 RPM at that 47mph in 2nd. Even worse, 47MPH is 2951RPM in 3rd! Redline on 12v is 3000, with most of them being lower because of hard defueling. All of this was with a load of 10,800lbs. Which leads me to believe I can't trust any of their data at all. Funny when they mislead you on something you can calculate to be absolutely wrong
