Hard to start
Just to follow up with this I just replaced the fuel lines and mounted the lift pump on the frame.  Not 100% sure but I think the hard fuel line on the return from the banjo fitting had a small crack under the protective hose going down to the frame,. There was a clamp  on the bottom of it after I put air pressure on it the hose was full of fuel.  I replaced everything and now it starts with the front on the shale pile at a 45 deg angel. The leak was so small I don't know for sure if that was the case or not, thank the good Lord it is working great now,.    Thank everyone who helped me on this site.
So you replaced the entire hard fuel line? Where did you find the replacement at?
