Cluster Odometer mileage
Guest 04Mach1
2 hours ago, dripley said:
I would like to see my hours, where did you do this?
He says Cummins Insite. Most truck dealers and shops have the software. I'll have to check it out with my laptop. I just got to find an OBD adapter to hook to my Cummins inline 7
Correct CUMMINS INSITE software, connected to cummins bus (CAN bus, 3 pin connector by injection pump)
EDIT:
On 1999 connector location close to the injection pump, newer trucks probably have this connector closer to the ECM:think:.
Guest 04Mach1
Nice. I wasn't aware there was that option to connect to the ECM on our trucks. I'm definitely going to check it out. I might already have the connections for my Inline 7 since it's a direct ECM connection.
