1999 ram 2500 Driver Side Power Window intermittent
All of the driver side switches work e.g. locks, passenger, driver auto down/manual down. however when you select drivers side window up... it goes up about halfway and stops... you have to wait for a good amount of time approx. 15-30 mins it will go up some more then stop and you have to do that process until it all the way up.... any ideas?
Check the wiring going through the door post/frame area by the door hinges.  I had one break the wire in there.  It would work if you wiggled it. I would think you could pop the switch out and check for power when its not working to verify weather its a switch or power issue.
