High idle kit issue
So I installed my high idle switch this after noon and I'm have issue with the temp gauge shooting up to +200 in 6cyl settings. I tried shutting the truck down then switching settings. Then starting it back and the issue goes away in the mpg setting and 3cyl settings.  I tried the 6cyl setting again and same issue. I uninstalled the unit now it goes into 3cyl high idle with out the unit being installed. I have it set to the off position now and it idles normal now. Any ideas on trouble shooting the issue. I followed all the install instructions and check the wiring for any pinched wires or connecters not being plugged in all the way and everything checked out.
Email support@mopar1973man.com  and we will get a new switch out to you.
I have been looking at the recent issues that have come up and it appears that the batch of rotary switches are causing issues.  I have since adjusted my testing to ensure that the rotary switch is in good shape.
