Was losing air for last few weeks, found a leak in a tire valve. It's leaking where it goes through the rim. I took it out and it was starting to tear. I have 4th gen rims and I believe the size is Tr413 .453" My question is can I use any valve or does it have to be a truck specific. I have some Milton ones that I use on everything else, just not sure of psi rating. The one that came out used to have tpms sensor attached to it, po kept the sensors when I got the rims, valve works without the sensor.
