For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
Got a P1698 this morning.
Recently had my ECM repaired by ACS. The truck has been running fine since installing the repaired ECM, and doing the ground mod.
Leave for work this morning and the truck is stumbling and billowing white smoke which I know is due to the failing VP44. However, the dash dings, lose all gauges, ABS, brake, Air bag, CEL, low fuel all illuminate.
I cycled the truck on and off two times and the gauges were working, but had a CEL light, only codes P1698, P0216. Still able to pull codes with scanner. Drove to work fine. Went to move my truck and no bus again, no gauge cluster, and all lights illuminated. But the truck still runs and drives with no issues. Is it possible the ACS repaired ECM could be causing issues or is this ground related?
