Borg Warner sxe300 62 65 14 turbo :)
Thank you me to. I running better on the bottom end than hy35 but I think that my boost leak was present with it to.
I've yet to see more 40plus psi but honestly I dont think I need it but would be cool to hit just say yup I'm there with ya. Lol
Thought about messing with timing to see if psi would come up but decided against that. I dont have head studs in yet so that maybe asking for trouble
Looking forward to towing see what kinda temps are going to happen and also maybe see some higher psi #s under a load.
Very impressed with the feel of this motor now. Shes also got alittle turbo whistle at idle and exhaust tones louder now that waste gate is good and closed. It just keeps getting louder. The low rpm light throttle drone is taking some getting used to. It's not horrible but with hy35 it was a pretty quite truck. Maybe the true 4" down pipe is to blame for the noise
Edited by Evan
Mike
Broke 40psi with goosekneck and skidsteer on today egt sustaining under 1200 temps dont seem to go higher with more pedal.  Hy didnt care more pedal more heat at same rate as pedals pushed.
One thing I noticed is it seems to get to 1100 quick wich had me concerned but then it just stops building heat. This is flat ground though, hope it acts the same pulling grades
