Rear door hinge pins
Hi has any one found a hinge pin rebuild kit for the rear doors on a 1999 ram 3500. I talked to doorman and they make nothing for the rear doors> I also checked LMC and Rockauto and they don't list anything for the rear doors hinge wise.
Dale
I checked with Dorman and they only have pins for the front doors. I will probably drill them out to the same size as the front and use the front pins. Just find it funny you can buy them for the front but no one has rear pins. They must seldom need replacing.
Dale
