Pictures will come later as they are buried in my phone but its really simple. As a disclaimer, use common sense, see what other things i've got done to my truck and take that into consideration before you do this. I am not responsible or liable for anything that happens.
For what its worth i am working with a stock truck. No "real" mods or upgrades..
You will need-
1- Eye bolt (with 2 nuts and 1 washer) (i think 1/4 inch is what fits through the old wastegate holes) home depot for less than 5 bucks
1- extension spring from napa part# 7704099 (balkamp) about 2 or 3 dollars
1- 1/8 pipe plug to plug hole in turbo compressor housing left over from factory wastegate air line - oreillys has them but they are pricey at about 5 bucks
So i was able to this fairly easily. I learned the hard way that you cannot remove the wastegate with the circlip attaching it to the wastegate lever.
First get that stupid circlip off. I used a flat screwdriver with about a 1/4 inch blade and from underneath the truck i pushed up carefully and was actually able to keep that clip on the blade of the screwdriver and not have it go flying down the driveway. You have to reach way up there to get to it.
Next take the wastegate off by removing the 2 nuts and its air line. I found this to be rather difficult. My air line was really stuck to the wastegate and fought it for a while.
With all the old wastegate parts out of the way you should now plug your old air line port with the 1/8 pipe plug (i actually stripped the fitting and still cannot remove it from my turbo so i have been running with a bolt in the hose with a hose clamp squeezing it in place, verified good up to about 28 psi)
This is where i had a really hard time, getting the spring to stay hooked onto the wastegate lever. I tried combinations with washers and ultimately i dont remember what i ended up using as a final solution but when i go to get a finished picture and update the post i guess we will know. But i had a very difficult time with that bit there.
The final step is to apply tension to your brand new wastegate. I did not get scientific by any means at all. I havent the faintest idea how much tension is on that spring. All i can say is really well snugged up and stretched out. I did double nut the eye bolt to prevent it from loosening over time with your typical road scenarios ie: vibration/heat. But i took into consideration that it was about a 40lb spring when i did this.
Now i will say i have not adjusted mine at all. I put this together back in May and havent really touched it since. I took it for a test run on a freeway onramp near my house and saw my gauge read 29 psi and at that exact moment i lost an intercooler boot. Fortunately i just had about 20 years of oily residue built up and every last one of my boot clamps was LOOSE.
Since May I have maintained about 27 psi as a peak at the current spring setting which hasnt changed since i put this together. Reliability seems excellent. Have had zero issues with it aside from the intercooler boot popping off. This includes several trips to Phoenix from the az mountains as well as 2 trips to california. I have yet to really tow with it but i have moved my enclosed across town a few times since then and it hasnt affected it at all. I thought heat would soften it up and lower my boost but no changes even after several hours in the heat (driving across the 10 down to hwy 8 gets hot even at night in august its 100). The wastegate flutters pretty good with a spring on it vs the boost pressure style and your working with drive pressure solely and not boost pressure which changes things.
Overall i would say for those in my position (broke, bought a second hand edge that did not come with any of the boost mod parts, needed more air) it is definitely a worth while mod and its cheap and super easy all things considered. I was able to increase my combined average mileage from 12/13 mpg to 17 based on the trucks computer and my commute/driving style (half highway,half city. 5200 ft to 5800 ft elevation). The trucks computer its about 1 mpg over what im actually getting when i do the real math. If you spend more than a day doing this project than your getting distracted or something is wrong. Actual time working was about an hour or two if im being honest.
Fit and finish is far below what i would consider professional, clean, bad, etc. Its ugly but functional.
Hope this helps (i will tag those who were asking about this)
  • Replies 5
  • Views 3.7k
Damn flies, there every where.
Alright so i had a single picture and it wasnt worth anything so i took new ones. Pretty straight forward. And there is a washer between the spring and the circlip. I dont know what size i found it in my literal bucket of spare hardware but there is a washer there to keep the spring from finding a way past the circlip. I remember using the old wastegate linkage for comparison now that i think about it.
Anyways heres pics
Zoomed in on spring for spacing
Front view
Top view
Ghetto hose plug
Underneath zoomed in. Hard to tell but there is a washer on there
Underneath zoomed out
You can see my super ghetto boost plug... its worked for now because the top of that fitting is so stripped its not even funny..
Not the prettiest as i said but its functional. I tried to get a good picture of how far the spring is stretched and its not much but it is way easier to tighten the nuts if you have a pry bar to help stretch it. Then you can quickly spin the nuts on and not have to fight the spring.
This is my take on a budget "performance" upgrade. Hope it helps someone out.
Edited by Me78569
Made it easier to tell links apart
I havent tried to adjust it but given its a 40 lb spring i think im at my limit with 27 psi since im now working with drive pressure and not boost pressure as my regulating force.
Did This Forum Post Help You?
