Identifying a couple wires and their locations
So my OD hasn't worked in a while and I just had my transmission built a few months ago. Took it to the shop and they said this wire is the reason it's not working. Could this be it? It's a twisted pair wrapped. I haven't found any spot where it could connect to, and I've searched top to bottom. Any help would be appreciated
Edited by Rather Be Wheeling
Pairs not single
No, that is not wiring for the OD;   That is under the dash next to the HVAC vacuum lines and may go to the HVAC control panel but twisted wires are used in the airbag system .  You need to strip back the cover and see what are the wire colors.
Edited by IBMobile
