Power mirrors on a non power truck?
i see that my truck already has the connectors in the doors for power mirrors and the control switch on the drivers door.
do I need to do anything other than get a mirror control switch and a set of power mirrors to do this?
Would it be the same for heated also? Pulled back the ac/heat controller and the wires are plugged into a empty spot on the controller.
Is there a need to put in a fuse in one of the empty spots on the fuse block inside the cab or is it all powered already.
thanks
I installed them on my truck that came with manual mirrors and it was all pug and play. The heated part will need an hvac switch that has the on off button. They can be had used very easily. I believe the truck has to be an SLT or better for the wiring to be there. Sounds like you are seeing what you need.
