truck turns off when put into drive
hey guys i currently have an issue with my truck, i recently replaced the intake pump and injection pump and it has been fine all the way up until now . yesterday i was sitting at a red light and the truck started pouring out black smoke and felt like it wanted to take off. so i put the truck into neutral and when to put it back into drive then it shut off, it did this about 8 times then i got frustrated and held my foot on the gas and put it into drive and took off. it does feel like its under powered now  almost like in limp mode.
  • Replies 2
  • Views 1.4k
when i bought the truck about 4 months ago it had a reman new transmission in the truck , fluid is clean , i haven't had a change to bring a scanner home from work to check for codes
and the fluid color is bright red , its not dark or burnt smelling at all
