- Replies 3
- Views 1.1k
Mopar1973Man 1 post
Great work! 1 post
Sugmadique 1 post
I’ve been having hell with my ‘99, it’s a 2500 4x4 with an automatic trans. 130,000 miles all stock except for a few cosmetic things. One day out of the blue the trans went into limp mode, I hooked up my scan tool and I didn’t have any communication with the transmission. I started checking wiring harnesses and senors on the transmission. Found the output shaft speed sensor was bad so I replaced it and now the truck shifts 1-3 but has no O/D. It’s not my daily driver so I let it sit for a few days and came back to it when I had some time and I noticed it wasn’t charging the batteries and the A/C wasn’t working either. I wanted to verify that the it wasn’t each system failing at the same time and I jumped the a/c clutch relay and the a/c began cooling. The alternator tested fine so I put an external voltage regulator in the alternator and it began charging. I added a switch to the trans relay and the O/D solenoid engages. I was leaning towards the PCM being failed so I checked the power and ground to the PCM and it had both and no communication with the pcm and no codes so I ordered a rebuilt one ($600) and when I installed it, I still have the same issues. I’m at a loss here, how does the PCM know to turn accessories on? I was told that the CKP sensor is how the PCM knows the engine is running and turns everything on. I had an intermittent No start, and no tach issue with codes for the CKP sensor so I replaced it with an eichlin part. The engine starts and runs so the CKP sensor has to be good right? I also have replaced the APPS after a no throttle response issue and fixed that. I checked my 5v reference on the ECT and it was fine, that means the 5v on the pcm is fine, correct? Is there a way to check the CKP sensor without a Scope? I had a industry friend tell me that it could possibly be my batteries are toast (optima red tops). They’re old but the truck starts fine. Any help is appreciated, thanks guys.
