Wiring Harness Swap
Will the engine wiring harness from a 01' 3500 2wd manual transmission work on a 01' 3500 2wd automatic transmission. If so is there any modifications that need to be made.
Thanks in advance
  • Replies 1
  • Views 1.2k
Make sure you have the right wiring then there is no modification you need to do. The only one is after you install is the W-T ground wire mod. Maybe the PCM protection fuse.
