Hello All,
Over the years I have jumped around the different fueling boxes.  I have uncovered my old edge comp box without the wiring harness.
I can get a new harness for $150.00 from Edge but before I shell out $150.00 for the harness I would like to verify my box works. I called Edge and they told me that my box is too old, build date of 12/31/2002, and they no longer support testing of this box but can provide the wiring harness.
If someone out there has a wiring harness that they can provide a wiring diagram so I can make my own, or if I could plug my box into someones truck and confirm it works before I shell out $150.00 to buy a new harness from Edge.
I am in the Sacramento California area.
Can someone out there help me?
TIA,
Brian
  • Replies 11
  • Views 3.2k
Let me dig my old Edge Comp out I've still got mine in the shop somewhere and I'll dig it up and give you pins and wire colors and going to what. Mine is a 2002 edition of the Edge Comp so it might vary a bit.
A wiring diagram would be great.
  • 3 weeks later...
Were you able to dig out the wiring harness?  Please take this as being pushey.
Thanks Brian
This is perfect!!!!!!!!!! Thank you very much!
Red wire, that is power wire?
Brian
Red is the ignition power from I think fuse #9 in the cab.
If your having trouble identifying colors and placement let me know.
Good Evening All,
Any suggestions as to who sells OEM style connectors, both male and female?  I am searching the internet now and was wondering if anyone has already found a good supplier.
Thanks Al.
Brian
For the wiring,  Is this correct?
Tab Up Left to Right
#1           LT. Blue                =             Data Link
#2           Blue                      =             Data Link
#3           Tan                       =             Map (male or female)
#4           Black                    =             Ground
#5           Red                       =             12+ Supply
#6           Green                   =             Map (male or female)
#7           White                   =             Map (male or female)
#8           Grey                      =             VP44
Thanks,
Brian
If you are interested I think I have the whole thing (box and harness).
Not using it, and they are mostly obsolete.
$50 and I'll even send it to you.
I will send you a PM
