We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features. Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
- Replies 10
- Views 1.7k
Archived
Did This Forum Post Help You?
Dropped on a set of brake calipers for a 3rd gen both fronts and rears to rebuild, they were is a sorry state but £10 for all 4 is ok.
Pistons were well and truely seized, tried a few things to get them out, wouldn't budge using compressed air so settled on a 24mm metric coarse taper tap which taps into the piston end just nice, a 24mm nut screwed onto the tap before turning it into the piston gives a nice flat surface to lever against, this pulled all 8 out, if this would have failed I was going to machine a tube to sit over the piston and a big washer and use the nut and tap to pull the pistons out... didn't need to in the end
I found it best to leave the steel end cap on as it gives the piston a little more strength
Going to get them blasted and then rebuild
