Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
Does anyone here have or know of an edge comp box that is either damaged or for sale cheap? I need the faceplate with the power and adjuster buttons.
My box works but the contact coating on the increase button has flaked off. I tried a product called CaiKote 44 which is a conductive coating for the membrane switch, but getting everything apart and cleaned up has taken the "pop" out of the button. If that makes sense.
There are only four solder connections to remove and replace the faceplate so if I can find one that would simplify this repair.
