- Replies 14
- Views 6k
Dynamic 6 posts
Kodiak24V 6 posts
Mopar1973Man 1 post
IBMobile 1 post
Popular Days
Any time there is flow across a fixed orifice, there will be a pressure drop. If you're leaking oil at the servo, you will see a reduced pressure because the oil that is flowing to the leaky servo has
Yeah, it sounds like you may have a bit of a confused package there. It's really tough to say what all was done and not done, what parts were used, clutch counts, clearances, stall speed of the conver
2001 Ram 2500 24v 4x4 excab shortbed.
Auto, S363, 7x.010, 4.10 gear. 36” tires.
had a local shop build my transmission 3-4 years ago with billet torque converter, billet input. transgo kit.
trying to learn more about the transmission so I can do it myself next go around.
ran some diag checks and had a few questions about the results.
1 pressure gauge on the accumulator port and 1 pressure gauge on the front servo port/rear servo port.
FRONT SERVO:
3rd-4th gear locked WOT-
accumulator pressure 145-150psi
Front servo pressure 135-138psi
the spec in (47re trans line pressure port testing guide) is 3psi difference at stock pressure
is 10-12 psi lower pressure difference in the front servo @ 150psi a problem?
REAR SERVO:
Low 1st gear-
accumulator 135psi
Rear servo 130psi
I assume 5psi difference is ok on this one as the spec is also 3psi at stock pressure.
reverse gear-
Idle 240psi / full throttle brake boost to 1600rpm 315psi
im assuming that’s good?
I originally had an issue where turning the pressure adjuster on the transgo VB didn’t return more pressure.
I didn’t do these tests before hand but I did change out the Valve Body with one built by one of the popular diesel drag racing companies. Owner said they test each one on the machine for 140-150psi before sending out.
I have turned the line pressure adjuster 4 turns out and also changed out the old plastic accumulator piston and stock 2nd gear servo with TCI billet units and am seeing the pressures above. max high 140s to 150.
just not sure because I was told it shipped out at 140-150 and it’s taken 4 turns to get to those numbers.
Going by 10psi per turn it seems I should be at 170-180psi.
before I go in and keep cranking the pressure adjuster I wanted to make sure these numbers looked ok (no internal leaks)?
