Straight Axle Front End
Im having heck trying to find straight axle parts. Is there something else you call a straight axle?
  • Replies 3
  • Views 1.4k
have you used the part number lookup tool and just searched using the part number?
Looking to replace tie rod ends, pretty much all steering related parts. When I look up straight axle, and Ive changed it up a lot I keep getting 4x4 parts .
Got it.
I cant believe there can be so many ways to search crap, geez. Apparently they made a straight axle with leaf springs. Did a search for coil spring set up and got it.
Using the part number lookup tool for a 2002 you can see the group 2 section that starts with 2wd front end.
  It has the part numbers for everything you need.  Plug those part numbers into rockauto.
