Fuel pump replacement (in tank)
Looking for a good replacment for the in tank fuel pump for a 94 2500 12 valve fuel system.  Old one says Carter, but Summit images don't look similar.  Any help on a good quality replacement brand and model number?
  • Replies 11
My 92 that I had for 23 years never had an in tank pump, ran off the cam,  mounted on the side of the block. Later on I changed the original mechanical pump, lasted 250 k, so I thought it time to change. Never had the newer version go more than 100k miles. When comparing new to old, bought from Cummins, the newer was built cheaply. I would go for one on the frame with a prefilter.
I’m not super well versed, but all the 12 valves I have seen, trucks and industrial, were mechanical pumps that ran off the cam, like @JAG1said, with the hand primer.
Only you don't want those screens in the bottom if they are there.  Remove those and provide a nice water separating prefilter before the lift pump then a high micron factory filter before the injection pump. In my opinion the 12 valve high micron factory filters under near the intake are way too dinky.
Forgive me if I am repeating what you probably already know... need emoticon that has the whole crowd rolling their eyes at me. :lol:
34 minutes ago, PilotHouse2500 said:
Thanks...now I have to remember that!  :)  Fuel system plumbing will be next summer/fall likley.
Forgot to say that it's good to have shut off ball valves on the fuel line before and after the prefilter. I helps prevent priming loss, fuel drain back. Also use them to shut off fuel in bad neighborhoods to prevent theft. I think there may be a way to put a lock on any of the two shut off valves. Haven't figured how. Mike knows a good way for security. I wouldn't want a truck like yours to get taken since it is an eye catcher.
yah I was planning on some ball valves...I have several things going for me for anti theft...its a manual, and its starting method will be...non standard!
Archived
  • Current Donation Goals
    • Raised $20
