Pulled my box off for an easier install for the Fass. Does this look like an in tank pump retrofit? Does anyone also know what this port should be connected to? Is it just a breather ?DA930EE7-690C-4335-9F5A-7ABBCE9B4FBA.jpeg.3343557b39261137fe2627c25ce92887.jpeg
  • Replies 6
  • Views 1.2k
  • Tractorman
    Tractorman
    I believe it is a vent / rollover protection valve.  It should be present on all fuel modules.  I have one on my fuel tank module.   - John
- John
- John
Correct. Tank vent with a rollover valve. Make sure the nipple is clear and not blocked.
How would I know if I have an in tank pump? I’m out of town for work so I don’t have access to the truck. Only that picture I took of the electrical on top
If it was a dealer retrofit, there may also be a relay hanging in the corner of your engine compartment, driver side by the firewall.
