Shredded my Headlamp to dash Wire-harness
Hey guys,
I was towing up hill today and somehow the wire harness that runs horizontally across the front frame cross member underneath the radiator fan came loose and got sucked into the fan. 13 wires got shredded. I replaced three blown fuses and managed to splice everything back together and got everything working (headlights, turn signals, hazards, windows, overhead display, etc.) EXCEPT my Power lock function. The unlock works on the driver side and passenger door but not unlock.
i’ve been looking for about two hours now for a wiring diagram and can’t seem to find one for that harness.
does anyone have any input on what I should try or am I missing something?
I didn’t check relays. there are also two gray wires, two black wires and two Green wires with a purple stripe (I think) in the run that got shredded- I tried connecting the doubles together and then reversing the doubles. Unlock will still not work.
hope this makes sense. Thanks!
