- Replies 4
- Views 776
Mopar1973Man 1 post
IBMobile 1 post
Tractorman 1 post
5akman 1 post
Popular Days
The diagram below shows how I wired my 1999 truck with a 47RE transmission in stock form (3rd and 4th lockup only) when the truck was new. I used a momentary foot switch in series with a throttle swi
Getting ready to get a 30' bumper pull and ProPride hitch to tow with the rig in my signature. The PacBrake electronics tie into the lock up wire at the ECM to activate the exh brake when the unit is turned on and foot comes off the accelerator. If I wanted to add a TC lock up switch so that I can lock up in 2nd gear on up (Dynamic VB modded to allow that) for towing slow up steep inclines, can I do this without inhibiting the use of the exh brake? I'm assuming that I'd leave the PacBrake switch "off" and use the lock up switch as needed climbing hills. Then when going downhill, turn the TC lock switch "off" and turn on the PacBrake. Anyone have any wiring info on this? Since the Pacbrake is initially wired into the TC lock up wire, where in that circuit would I tie in to operate the separate lock up switch?
Edited by 5akman
further questions
